I had simulated Galvo scanner for beam positioning on square field area. I want to know how can I see beam diameter or radius (in mm) of elliptical shape spot (generate for higher scanning angle).
Best answer by Ethan
Hi
Apologies for the delayed response. In case this question is still relevant or for the benefit of others, I wanted to let you know about the Spot Diagram feature in OpticStudio. Here is an example elliptical shaped beam:
If you select the Text tab at the bottom of the analysis window, you’ll see additional data:
In the Text analysis, you will see that the output not only specifies the RMS Spot Radius, but also the RMS Spot X Size and RMS Spot Y Size. These parameters will help quantify a non-circular spot.
I hope this helps, and you can find more information on the Standard Spot Diagram in the Help File: The Analyze Tab (sequential ui mode) > Image Quality Group > Rays and Spots > Standard Spot Diagram .
Ethan
