Getting the Ray Spot diagram/Seidel Aberrations from interferometer data
  • Mar 23, 2025 12:28 AM UTC
  • 197 views
Diptayan
Hi Everyone,
I am trying to get the seidel aberrations and ray spot diagram for a surface of which I have only the interferometric data (captured by a zygo white light interferometer and processed in their MX software). I think I have successfully imported the data from the interferometer’s software to Zemax as the peak to valley sort of matches. But I am seeing no difference in the ray spot size and seidel aberrations. I am uploading the link to the files as it is a big one (both Zemax and interferometric data). Kindly help me or suggest what the issue is.
Zemax File
Thank you.
Best answer by Rishab
The pupil plane should be matched to the grid sag surface, so consider making it as the stop.
Rishab
  • Mar 25, 2025 5:05 AM UTC
