Why does my macro output results from 1 previous macro run?
  • Mar 14, 2025 9:33 AM UTC
  • 160 views
HM Light
I have a question about Zemax Macro. My macro outputs the results from 1 previous macro setting, even though I edit and save the new setting in the macro every time. I put the screenshot that explain this problem. I have no idea why it happens, so I would like to have any suggestion and comments.
Best answer by Sean Turner
Try adding the UPDATE keyword before RAYTRACE.
Sean Turner
  • Mar 14, 2025 12:27 PM UTC
HM Light
  • Mar 14, 2025 11:54 PM UTC
Thank you so much! Yes, it looks like the UPDATE is needed before RAYTRACE. It works well after adding the UPDATE.
I found the description of UPDATE in the user manual. Much appreciated.
