How Can I Add a Detector Cylinder?
I am trying to simulate an LED that shines into a cylinder tube and I want to measure how much power is deposited into the cylinder tube walls by adding a detector cylinder but such a detector doesn't exist.
I've been using Detector Viewer on Detector Surface to check what the power in watts is, but even though I select checkbox "Object Is A Detector" in Object properties, it doesn't show up in Detector Viewer. I guess it makes sense because how do you show a map of the detector cylinder, but is there another way to measure the power going through the cylinder detector walls?
Best answer by Aditi.Dighe
I agree that the drop down menu does not show the detector selection. The text tab, however, does show the detector in the drop down menu, with the name as is written in the object comment. Here's a screenshot to explain better- my custom detector does not show up in the drop down menu for the graphics tab of the detector viewer, but it does show up in the text tab of the detector viewer.
I hope this helps! Sorry if I misunderstand the issue. Good luck with your design!
View originalI hope this helps! Sorry if I misunderstand the issue. Good luck with your design!
