Hi
I tried to understand the Ray Fan in OpticStudio and ran into this problem
I have a paraxial lens imaging an on-axis object (zero height) with 10 mm semi-diameter pupil size and focal length of 50 mm. Image plane is shifted 5 mm away from the focus intentionally, so it is at 105 mm from the lens. The Ray Fan plot is like this
Defocus term is the slope of this line and equals 0.05. Considering the defocus formula DF = focus shift x marginal ray height (10 mm) / focal length (50 mm) gives a 0.5 mm focus shift instead of 5 mm. I am not sure if I have problem with the definition of defocus term or with interpreting the Zemax data. Any idea?
