Diffractive macro DOESAG.zpl is not available
I am unable to find DOESAG.zpl macro for getting the sag values for the diffractive aspheric surface. Earlier it was available in the knowledge base but now that is also not there.
Can I get this macro as it is very useful to view the steps of diffractive surface and surface sag data
Regards
J Himavanth kumar
Best answer by Chris Normanshire
You can find the DOESAG.ZPL macro attached to this Knowledgebase article How to calculate the sag of a diffractive optical element with a macro – Knowledgebase (zemax.com). Let us know if you have any problems though.
Chris
Chris Normanshire
Chris
  • August 19, 2021
Thank you chris ,
I got it
  • July 8, 2023
Dear
I wonder DOESAG.zpl macro works correctly. When I compare sag of a binary2 surface using surface phase crosssection in analysis and DOESAG.zpl macro, the results are different. Could you check whether this macro is correct to calculate phase and sag?
  • July 8, 2023
Dear
  • July 8, 2023
Dear
Sorry, DOESAG.zpl is correct. this macro shows sag value from DOE vertex. the result from Sag = (phase from Surface phase crossection) x (step height) shows the value from DOE base surface. so, two result are the same.
CRISTINA.sanc
Hello everyone, thank you very much in advance.Could someone tell me why I receive this message when I run the macro downloaded from: How to calculate the sag of a diffractive optical element with a macro – Knowledgebase (zemax.com) ??
The line 85 is:
iter_num = sdi / step
Do you think the error is in "sdi" since it should be "sdia"?
CRISTINA.sanc
