Image simulation
  • November 9, 2020
  • 129 views
Ian
  • 14 replies
In the Image Simulation outputs the region at bottom left shows useful data.  I would like to request that the input file name be added to that list.  It would make repeating an old analysis easier by being sure I'm using the right file.
Allie
  • 338 replies
  • November 9, 2020
Hi Ian,
I have submitted a feature request on your behalf! Can you let me know - have you tried clicking Save in the settings dialog for Image Simulation? When you do so, two configuration files will be saved: a project-specific CFG file will be saved to the working directory, and SIM.CFG will be saved in the Zemax\Configs folder.
SIM.CFG will denote the default settings of the window when opened in a new file and may be changed at any time. Conversely, the project-specific CFG file will remember the input settings for all your analyses for that specific lens file. That way, when the project is re-opened, everything should be the same - including the input file. Would that work for you instead? If not, why?
Allie
