How to set the image surface tilt and decenter as compensator
yuan.chen
What shall I do if I want to set it up in tolerance data editor?
Best answer by yuan.chen
This can be modeled by using CPAR with a coordinate break surface introduced in front of the image plane
A sample file is attached for your reference.
yuan.chen
  • 275 replies
  • July 18, 2023
yuan.chen
  • 275 replies
  • September 4, 2023
Add Z position variation as compensator using the operand COMP.
