Dear All,
I am interested in desiging an optical design for an instrument that will have a slit width of 20µm (with a 3mm length). Now, how can this be defined for the system?
Thank you very much.
Naif
Dear All,
Naif
Best answer by Berta.Bernad
Hi Naif,
You can directly apply a rectangular aperture defined by the half widths in x and y:
If working in Non-Sequential Mode, you can use a UDA file to create your user defined aperture, and then apply it on a surface. To have more details about the UDA file format, I recommend you have a look at the help files as such: The Setup Tab > Editors Group (Setup Tab) > Lens Data Editor > Surface Properties > Aperture (surface properties) > User Defined Apertures and Obscurations.
