MTF calculation with all Wavelengths
  • January 27, 2025
  • 90 views
mocquin
Can you confirm that when computing the Fft Mtf with “All” wavelenghts, the resulting MTF is the weighted average of all individual monochromatic MTF ?
The doc only mentions “Wavelength The wavelength number to be used in the calculation.”, but does not explicitely states what happens if “All” is selected
@mocquin
This might be helpful:
More specifically, if you look at ​@Jeff.Wilde’s answers. It seems that:
if you compute the weighted average of the complex OTF functions, then take the magnitude, you will find the same polychromatic MTF result that OpticStudio calculates
Which Jeff verified:
  • 1089 replies
  • January 27, 2025
@mocquin
