Holographic Lens NS behaves different than Hologram1 in Sequential
  • December 9, 2020
  • 38 views
sz
  • 7 replies
A Holographic Lens in nonsequential mode should behave the same as Hologram1 and 2 in sequential mode.
I used the same parameters to collimate a pointsource under an angle. But while the sequential system is working as suggested, the non sequential is not...
I have attached two files to show.
Can not find a mistake... a bug???
Best Regards
Steffen
sz
  • 7 replies
  • December 9, 2020
Sorry, found it direct after Posting.... Element is inverted (light is comming from the back) in ns...
Post can be deleted!
Best
Steffen
