Hello Zemax Community,
I’m trying to understand the meaning of the numerical value displayed in “AXCL” and how it’s calculated. The definition I found states: “This is the image separation between the two wavelengths defined by Wave1 and Wave2,” but I’m still unsure how to interpret that in practice.
In my lens design, for example, the maximum focal shift is around 256.0465 µm, yet AXCL shows a value of -0.044014. I’m not sure what the negative sign means or why AXCL is so much smaller than the focal shift I see elsewhere. Is AXCL supposed to represent the chromatic focal shift, or is it defined differently? Any clarification on how AXCL is computed and what it physically represents in an optical system would be greatly appreciated!
Thank you in advance for your help and insights.
