Python NSC Examples failing with AttributeError
svilches
I've tried running the example file PythonStandalone_02_NSC_ray_trace.py and realized that it fails when trying to read out ObjectData:
numXPixels = obj.ObjectData.NumberXPixels;
Result:
AttributeError: 'IObject' object has no attribute 'NumberXPixels'.
The code runs flawlessly, except when reading ObjectData. I have spent a full day trying to debug this error without success.
I have also tried the methods outlined in
PPG example not working | Zemax Community
and
ZOS-API Python: How to deal with AttributeError and apply the correct enumeration | Zemax Community
without success.
Does anyone know how to continue debugging?
Note: using Zemax OpticStudio 22.2.1
Best answer by svilches
I have found the issue: The sample code does not work with the latest pythonnet (3.0.0.post1)! Re-installing it with an older version (pythonnet 2.5.2) solved it.
Ansys Staff
  • Ansys Staff
  • 374 replies
  • October 5, 2022
Can you confirm the fly's eye homogenizer is unmodified and Object 4 is actually a Detector Rectangle?  Line 185 in the example is hard-coded to point to Object 4 and this object in the unmodified file is a Detector Rectangle.  You will typically get this error if you're trying to read a parameter (NumberXPixels) on an object which doesn't have that parameter.
svilches
  • October 5, 2022
Hi @MichaelH, thank you for pushing me to double check. Unfortunately, the .zmx is unmodified, and object 4 is a Detector Rectangle, as expected:
Furthermore, I have found a similar issue with all the non-sequential examples that try to modify a property.
Maybe some useful information: obj.ObjectData returns an IObject, and not an IObjectDetectorRectanglewhich is what I'd expect (although I'm new to the API, so I might be easily wrong). Of course, an IObject, being a general object, does not have the NumberXPixels attribute:
I hope this helps!
  • 1134 replies
  • October 6, 2022
Hi svilches,
The example works for me in 22.2.1.
This is the result I got in Spyder
You are saying:
However, the code uses the *.ZOS file (this is the new file extension):
    #! [e02s01_py]
    # Open file
    testFile = os.path.join(os.sep, sampleDir,  r'Non-sequential\Miscellaneous\Digital_projector_flys_eye_homogenizer.zos')
Could you check this file as well? I’m attaching my Digital_projector_flys_eye_homogenizer.zos file for which the code works.
Lastly, try rebooting the computer, it does wonder sometimes for me at least.
svilches
  • October 6, 2022
Tilmann.Piffl
There is still an issue with this example, but I’m not able to install the older pythonnet version. There is no pre-build wheel for pythonnet 2.5.2 for my python version (3.12) and building from source fails.
Does anybody know whether there is any effort made to fix the problems with pythonnet 3.x.x?
  • 1134 replies
  • February 5, 2024
@Tilmann.Piffl,
It’s mostly fixed if you read the following:
However, the examples have not been modified to take this into account yet as far as I know.
