image analysis in matlab
  • May 27, 2021 7:42 PM UTC
  • 525 views
Is there is a way to build an image simulator in Matlab from zemax ?
Brian.Catanzaro
Sure... you can use the ZOSAPI to communicate back-and-forth between Matlab and Zemax OpticStudio.
You can access all the analyses in OpticStudio from Matlab.  You can:
  • Simulate images in OpticStudio and display in Matlab
  • Collect PSFs across the FoV and compute your own image simulation
  • Use the MTF for systems where the PSF / MTF are constant over the field and use linear systems theory to compute the image
What do you want to do that is beyond these options?
  • May 29, 2021 3:37 PM UTC
Hi Brian,
Thanks a lot for the info & this is exactly what I need. Do have any resource material/any example of thread where the following topic is explained:
Looking forward towards your reply,
Kind regards,
saikat
Csilla Timar-Fulep
Thanks for your posts here on the forums!
Saikat, as Brian mentioned, this is all possible from the ZOS-API. If you would like to learn more about the basics of the ZOS-API connection, I would recommend to check out this learning path:
Getting Started with ZOS-API
ZOS-API.NET: An Overview
You may find complete examples, for example about how to pull the FFT MTF data, in the ZOS-API Syntax Help:
You may find further references and sample codes at these forum threads:
OpticsTalk: Deep Dive into Creating the Wavefront, Spot Diagram, PSF, and MTF in OpticStudio
How do I output the image of an analysis in ZOS-API?
How to extract the result of ImageSimulation in ZOS-API
Evaluation of PSF by on each pixel on the image sensor
I hope this helps, but if you have any further questions, we will be happy to help!
Csilla
  • Jun 2, 2021 9:27 AM UTC
Hi Csilla,
Thanks a lot for the information.
kind regards,
saikat
