Uploading multiple merit function via loop in MATLABStandaloneApplication code
  • November 14, 2024
  • 90 views
Rahul
I am working on designing lenses (Intraocular lens) of a power range and each power has unique merit function. I could manage to load merit function using the command below -
TheMFE = TheSystem.MFE;
mf3_filename = System.String.Concat(sampleDir,'\API\Matlab\MeritFunc\10.0D MF.MF');
TheMFE.LoadMeritFunction(mf3_filename);
In the same location I have merit functions for different power lenses. Can anyone suggest me a way how can I successfully load power specific merit function?
Thanks in advance!
Rahul
Hi Rahul,
It seems to me that you can adjust the filename of the merit function, or am I missing something? I am not that proficient with matlab, but something like this should work to loop through them:
1TheMFE = TheSystem.MFE;
2
3
4powers = [10.0, 10.5, 11.0];
5for i = 1:length(values)
6 mf3_filename = sprintf('%s\\API\\Matlab\\MeritFunc\\%.1fD MF.MF', sampleDir, powers(i));
7 TheMFE.LoadMeritFunction(mf3_filename);
8
9 % ...
10end
