Bug: Reverse Elements and wrong Row Color
  • September 19, 2022
  • 92 views
Alberto.Donazzan
When using Reverse Elements, Row Colors other than default are not swapped correctly between rows. The user defined color is kept fixed at its original row number, even after reversal.
Hi Alberto
Sorry for not replying earlier but yes this is a bug. I will report it.
Since it is a cosmetic bug, I won’t set a high priority.
Hi Alberto
Alberto.Donazzan
I understand. Thank you @Sandrine Auriol.
