I would like to simulate the reflected light from a ColorChecker tile (or even build an entire card) and use different illuminants in the system using the standard options for the Source Color (under Color/Spectrum) using different XYZ Tristimulus Values for different white points.
I have reflectance spectrum using a spectrophotometer which uses D65 illuminant
- How you make a surface with a custom reflectance spectrum ?
- Do I need to make transform my spectrum for each different illuminant I want to try?
Is this even something that can … should be done in Zemax? maybe that should be the first question
