Phase map for a spectrally large source
  • December 16, 2021
  • 69 views
On the sequential mode of Zemax, the source is represented by just one wavelength. I would like to know if it is possible to see the phase map for a source with a spectral width with the sequential mode of Zemax ?
If it is not possible directly, maybe I can save the value of the graph RMS vs Wavelength for my spectral range and after i will manipulate these data to add a weight on each wavelength ?
Thanks for your answers
Best answer by Mark.Nicholson
Nope: I mean the Universal Plot :sunglasses: It’s a special plot type that lets you define the x and y axes. Put wavelength on the X axis and something like OPTH on the y and you should have what you want.
Try a Universal plot where you scan the wavelength over whatever range while plotting the operant that corresponds to your y-axis variable
  • December 17, 2021
Thank you for your answer Mark !
By Universal plot, you mean the RMS Vs Wavelength ?
Because my problem in this case is that there is no notion of the light spectral distribution. I mean, if my source is centered at 625nm with a FWMH of 10nm, the contribution of 625nm in the phase map will be higher than the contribution of 620nm for example. And this is what I want to see : the final phase map obtained thanks to all the wavelength present in my light source but with the good contribution.
