Define transmission in material data
  • September 7, 2021
  • 163 views
Luca.cellerino
Hi all,
I need to define the transmittance of a material and I have as input the emission of the source in terms of CIE 1931 x, y and as output the measurement with the same standard.
Inserted the values in the Source Spectrum Plot of OS, I obtained the spectrum for 100 wavelengths of both the source and the target.
How can I combine the weight of each wavelength to generate the absorption values to be included in the material catalog?
I attach the Excel file used for the calculation.
Thanks in advance.
Sean.Lin
  • 54 replies
  • September 10, 2021
Hi Luca,
I have already replied to your Ticket. Please let us know if you have any other questions! Thanks~
Best Regards
Sean Lin
