I build a simple model with a Source Ellipse, two paraxial lens with the same f and spaced 2*f apart. So in theory from Source Ellipse are first focused by the first lens and then we can get a plane wave after the second lens. If we put a detector after the second lens, all rays hitting the detector should have the same coherent phase, but that's not the case.
Why paraxial lens cannot simulate optical path difference and resulting phase difference accurately?
