ZOS-API Initialization Error in Matlab
  • March 3, 2025
  • 5 replies
  • 470 views
It appears that there is a known ZOS-API initialization error when using OpticStudio 2025 R1.  Here’s what is stated in the 2025 R1 release notes:
I’m currently using OpticStudio 2025 R1.01 and encountering this problem with Matlab R2021a (which previously worked fine with OpticStudio versions prior to 2025).
Does anyone know if updating to the latest Matlab release will solve the problem?  If not, I wonder how/when this bug will be resolved?
Best answer by Prasath R
Hi Jeff,
Yes, it works for me. Updating Matlab to the latest release is currently resolving the problem.
Prasath R
  • March 6, 2025
Hi Jeff,
  • March 6, 2025
@Prasath R :
Thanks for your response!  I’ll look into upgrading Matlab and see if that works.
  • March 7, 2025
Yes, using the current release of Matlab works.  (However, the prior version, R2024a did not work, so updating to the most recent release is key).
  • April 29, 2025
I’m using update 6 and it doesn’t work.  I’ll go see if I can find update 5.
John
  • May 1, 2025
May 1, 2025:
Rolling Matlab back to R2024b, Update 5, did not work.  I then uninstalled Zemax 2025R1.01.  Then reinstalled Zemax 2025R1.01.
Now it seems to work.  I’ll assume it was the Zemax installation was fouled somehow.  I doubt that Matlab/Update 5 vs Matlab/Update 6 makes a difference.
