ZERN merit function
Adrian_J
The ZERN merit function seems to only give the Zernike values of the Image surface, but the Zernike coefficients are reported in the Wavefront Analysis table for ANY surface. I want to be able to extract the Zernike values for a surface other than the Image surface which are clearly available. How do I do it and represent it in the Merit Function Editor. The ZERN fucntion doesn’t have a parameter which will specify the surface of interest.
Would appreciate help if anyone has tried to do this.
Adrian_J
Best answer by Mark.Nicholson
Put an IMSF operand before the ZERN.
Adrian_J
  • July 22, 2022
Hi Mark,
Thanks very much for this! It has saved me a lot of time messing around trying to find alternative methods with macros.  Much appreciated!
Best wishes,
Adrian
