How to make a calculation in component editor ?
In component editor I can make a Pick up from other cell.
How to make a calculation ?
Dont only to choose but calculate the value from some cells data.
In fact, have a look at this example I made for you (you can download, and open the ZAR archive and the ZPL Macro will be installed for you automatically).
I made a ZPL Macro Solve, which returns the sum of the Y, and Z position into a cell (in this case Tilt About 😵.
I let you go through the article I talked about before, and read the Help File for the relevant parts of the code.
Hi Arkadiy,
I'm assuming you're talking about the Non-Sequential Component Editor. In which case, the feature you're looking for is a ZPL Macro Solve. So, instead of Pickup, you need to specify a ZPL Macro filename, and the calculations will be in that macro. Have a look at this article.
Let me know if this works for you.
  • 1085 replies
  • June 23, 2021
Hi David,
Thanks a lot of for your answer.
Thats really what I was looking.
Arkadiy
