Why do I lose power reflecting off mirrors with nsc tracing and the "use polarization" flag?
  • April 28, 2024
  • 107 views
I feel like I should know the answer, but for the life of me I cannot make sense of it.
If I create a very simple NSC model consisting of a 1 Watt source reflecting at normal incidence off a flat mirror and then absorbed a by a detector also at normal incidence, the power absorbed by the detector will vary whether I have “Use Polarization” checked or not.  With use polarization, the power is ~0.946 Watts, without it is 1.0 Watts.
What gives?
I am running an older version of Optics Studio but can upgrade (22.1.2).
Best answer by David
Optic Studio models MIRROR as a thin layer of metal which does not reflect 100%. For 100% reflectance you can use an IDEAL coating.
  • 336 replies
  • April 29, 2024
  • April 29, 2024
Thanks David.  Is this a change from older versions?  I don’t remember noticing this in the past.
  • 336 replies
  • April 29, 2024
It’s been this way as long as I can remember. It’s often been a source of confusion.
  • 490 replies
  • May 1, 2024
Just to add a bit more detail to David’s answer, here’s what the 2002 Zemax User’s Guide says:
