Glass cost optimize considdering material density
I try to optimize my lens system for lens cost.
If I use “GCOS” there is the “price per weight” but every glass has another density. So I would like to go for “price per volume”, but I do not find a way to get the density glass parameter into my merit function.
Is there a way to do so?
Best answer by MichaelH
Hi Sepp,
I don’t think you need the density parameter since the GCOS uses the relative cost and this is already an approximation, so the benefit of converting from weight to volume might not be worth it (lower GCOS/volume might be more difficult to work with so you will need to contact your manufacturer to determine the manufacturing cost for a given material).
If you want to get the density, you can use TMAS to get the mass, VOLU to get the volume and then PROD/PROB to do unit conversions to get the relative cost per volume (both TMAS and VOLU use centimeters regardless of lens units).
Also, if you really need to dig down into the raw material volume, you will have to calculate the blank volume using BLTH and DMVA.
Ansys Staff
  • Ansys Staff
  • 399 replies
  • August 8, 2022
Hi Sepp,
  • August 9, 2022
Thanks for the helpfull answer.
I know that the GCOS  is only an apprximation, but at least the approximation is getting better if I consider the real mass of the lens or as you say the blank volume.
A great thing would be, if we also could considder machinability of the material. My former boss tried to make a classification for Schott and Ohara glass 30 years ago, but I think there is nothing available in the community?
Alissa Wilczynski
@Sepp Can you describe more about how you measure/quantify machinability of a material?
  • August 29, 2022
Hi Alissa,
at my first company 35 years ago, we have got an additional list from fabrication about following properties in an in-house list:
  • stability of AR coating
  • high thermal expansion (this is already in your tables)
  • long polishing time
  • glass may be “bedded” (I hope I found the right english wording)
  • glas is not sutable for prism
  • glas tend to have blur after polishing
