If you system has vignetting, is there a way to list surface(s) are doing the vignetting?
Thank you,
John
Thank you,
John
Best answer by John.Hygelund
Hi Jeff, thanks for pointing out this ZPL function.
Not very elegant, but this does the trick! Much more efficient than manually stepping through the surfaces
1! Find vignetted surface23FOR I, 0,1,.14 RAYTRACE 0,1,0,I 5 V = RAYV()6 FORMAT 1.17 PRINT "Hy=1.0, Py=",I," first surface to vignette: ",V8NEXTExample output
Hy=1.0, Py=0.0 first surface to vignette: 0.0
Hy=1.0, Py=0.1 first surface to vignette: 0.0
Hy=1.0, Py=0.2 first surface to vignette: 0.0
Hy=1.0, Py=0.3 first surface to vignette: 11.0
Hy=1.0, Py=0.4 first surface to vignette: 11.0
Hy=1.0, Py=0.5 first surface to vignette: 11.0
Hy=1.0, Py=0.6 first surface to vignette: 11.0
Hy=1.0, Py=0.7 first surface to vignette: 8.0
Hy=1.0, Py=0.8 first surface to vignette: 8.0
Hy=1.0, Py=0.9 first surface to vignette: 8.0
Hy=1.0, Py=1.0 first surface to vignette: 8.0
