AR/VR相关资料整理
  • October 14, 2022
  • 5 replies
  • 3706 views
yuan.chen
整理了Ansys,主要是Zemax仿真AR/VR的相关资料,主要是知识库的一些文章,然后加上论坛里面一些相关的资料,比较多,可能需要慢慢消化。我会持续更新,可以考虑收藏一下喔,ღ( ´・ᴗ・` )比心
如果显示文章不存在,右上角语言选成英文的。
22/11/16:
增加了菲涅尔,人眼视觉以及一些学习路径。
23/03/27:
新增一个工具包,可以快速设定grating的参数
API (CS User Extension): Diffractive DLL Setup Assistant | Zemax Community
23/08/29:
新增Birdbath的优化以及偏振仿真
yuan.chen
  • 278 replies
  • October 14, 2022
知识库的学习路径,里面涵盖了AR的案例:
HUD & AR – Knowledgebase (zemax.com)
AR衍射光波导(surface relief):
Simulate 2D diffraction grating using customized diffractive DLL | Zemax Community
关于如何使用Zemax的RCWA工具进行EPE的仿真 | Zemax Community
Lumerical RCWA和Zemax OpticStudio的动态链接 | Zemax Community
Michael一直在更新这个dll,相关的更新记录可以参考这个链接
OpticStudio grating tools beta function update history | Zemax Community
体全息(VHG):
Overview of Kogelnik's Efficiency Calculations in OpticStudio
Modeling a Holographic Waveguide in OpticStudio for AR Systems
FAQ of volume hologram model in OpticStudio | Zemax Community
2023-07-05:这篇是在非序列里面建模的,很重要,多次被问到,记得看:
Building Exit Pupil Expansion (EPE) based volume holographic gratings (VHG) | Zemax Community
如上,这个dll经常被更新,相关的更新记录可以参考这个链接
Pancake:
Straylight in VR Pancake | Zemax Community
How to make a tolerance analysis for pancake optical system? | Zemax Community
如何快速了解偏振 | Zemax Community
自由曲面AR棱镜:(Freeform标题起得不明显,所以单独拎出来)
Designing a head-mounted display (HMD) for augmented reality systems in OpticStudio – Knowledgebase (zemax.com)
菲涅尔透镜建模:
How to model a Fresnel lens in OpticStudio – Knowledgebase (zemax.com)
How to model a complex Fresnel lens – Knowledgebase (zemax.com)
Birdbath:
Birdbath architecture for augmented reality (AR) system - part 1-System setup, optimization, and human vision simulation – Knowledgebase (zemax.com)
Birdbath architecture for augmented reality (AR) system - part 2 – Accurate polarizing element simulation – Knowledgebase (zemax.com)
杂散光分析:
Stray Light Analysis – Knowledgebase (zemax.com)
yuan.chen
  • 278 replies
  • October 14, 2022
yuan.chen
  • 278 replies
  • November 16, 2022
yuan.chen
  • 278 replies
  • November 16, 2022
镜像话题,都是人眼相关,有些东西是互通的:
HUD相关的资料集合 | Zemax Community
yuan.chen
  • 278 replies
  • December 6, 2022
