ZPL TASK 3
  • June 8, 2023
  • 188 views
Hi guys,
Task 3
  1. Plot the RMS spot size vs. through-focus position.
  2. Compute and plot the RMS value of geometric spot size, wavefront error, or strehl ratio over a linear field.
  3. Compute and plot the RMS value of geometric spot size, wavefront error, or strehl ratio vs focus position.
  4. Compute and plot the RMS value of geometric spot size, wavefront error, or strehl ratio over the two-dimensional FOV
  5. Compute and plot the RMS value of geometric spot size, wavefront error, or strehl ratio vs wavelength.
  6. Compute and plot the RMS WFE over the FOV.
  7. Plot spot diagrams over the 2D rectangular or circular field of view. The field of view is assumed to be centered on-axis.
  8. Macro that defines a function that returns the RMS Spot Size at any surface in your system. Can be used to constrain the spot size during optimization
Thank you!
