Overview of API commands to retrieve STAR Data
Below is an overview of ZOS-API commands used to retrieve STAR data.  The syntax is the same for most programming languages.
The list is far from complete; see the ZOS-API help files for complete information.
Also,I have not included any info about establishing the .NET connection, because it differs for each software package; see the OpticStudio Programming tab for information on how to connect to OpticStudio through .NET.
myStarData = mySystem.LDE.GetSurfaceAt( j ).STARDataTop level container for all STAR data.
myStarData.DeformationsAll structural data
myStarData.Deformations.CoordinateTransform - Holds info about any coordinate transform applied to the XYZ mesh.  Data is available in angles or rotation matrices, or a complete 4x4 matrix that includes all decenters and rotations.
  • myStarData.Deformations.CoordinateTransform.Enable()
  • myStarData.Deformations.CoordinateTransform.IsEnabled
  • myStarData.Deformations.CoordinateTransform.SetDecenter (dx, dy, dz)
  • myStarData.Deformations.CoordinateTransform.SetRotationMatrix( R11, R12, …. R33)
  • myStarData.Deformations.CoordinateTransform.SetTransformValues(R11, R12, …. R33, dx, dy, dz)
  • myStarData.Deformations.CoordinateTransform.Decenters
  • myStarData.Deformations.CoordinateTransform.Rotations
  • myStarData.Deformations.CoordinateTransform.Transform
Transformation of a point {x,y,z} to get the new point {x’,y’,z’} is defined as follows:
myStarData.Deformations.FEAData - Holds the raw FEA data
  • myStarData.Deformations.FEAData.ImportDeformations( filename )
  • myStarData.Deformations.FEAData.AreDeformationsImported
  • myStarData.Deformations.FEAData.NumberOfDataPoints
  • myStarData.Deformations.FEAData.GetFEAPointsSafe()
myStarData.Deformations.Fits - Holds the fitted data
  • myStarData.Deformations.Fits.IsSurfaceDeformationEnabled
  • myStarData.Deformations.Fits.Options
  • myStarData.Deformations.Fits.Settings
  • myStarData.Deformations.Fits.GetFittedDeformation_1( x, y, option)
    • option =DeformationWithoutRBMs, DeformationWithRBMs, NoDeformation, or OnlyRBMs
myStarData.Deformations.RBMs - Holds information about any Rigid-body Motions in the Deformation data
  • myStarData.Deformations.RBMs.Enable()
  • myStarData.Deformations.RBMs.IsEnabled
  • myStarData.Deformations.RBMs.Decenters
  • myStarData.Deformations.RBMs.Rotations
  • myStarData.Deformations.RBMs.Transform
  • myStarData.Deformations.RBMs.GetTransformValues()
myStarData.TemperaturesAll thermal data
  • myStarData.Temperatures.GRINStep
  • myStarData.Temperatures.SetWorkingWavelength() – Defines the wavelength used to calculate an index of refraction
  • myStarData.Temperatures.SetDataIsLocal()
  • myStarData.Temperatures.SetDataIsGlobal()
myStarData.Temperatures.CoordinateTransform
  • myStarData.Temperatures.CoordinateTransform.Enable()
  • myStarData.Temperatures.CoordinateTransform.IsEnabled
  • myStarData.Temperatures.CoordinateTransform.SetDecenter (dx, dy, dz)
  • myStarData.Temperatures.CoordinateTransform.SetRotationMatrix( R11, R12, …. R33)
  • myStarData.Temperatures.CoordinateTransform.SetTransformValues(R11, R12, …. R33, dx, dy, dz)
  • myStarData.Temperatures.CoordinateTransform.Decenters
  • myStarData.Temperatures.CoordinateTransform.Rotations
  • myStarData.Temperatures.CoordinateTransform.Transform
myStarData.Temperatures.FEAData
  • myStarData.Temperatures.FEAData.ImportTemperatures()
  • myStarData.Temperatures.FEAData.AreTemperaturesImported
  • myStarData.Temperatures.FEAData.NumberOfDataPoints
  • myStarData.Temperatures.FEAData.GetFEAPointsSafe()
myStarData.Temperatures.Fits
  • myStarData.Temperatures.Fits.IsTemperatureProfileEnabled
  • myStarData.Temperatures.Fits.Settings
  • myStarData.Temperatures.Fits.GetFittedIndex( x, y, z)
  • myStarData.Temperatures.Fits.GetFittedTemperature( x, y, z)
Be the first to reply!
