Polar detector
  • December 19, 2023
  • 109 views
Manikarnika
Why the angular and radial pixels of the polar detector affect the peak intensity and polar angle while the radial size of the detector is same?
How the pixels should be decided?
Best answer by Kevin Scales
The intensity for any pixel in any detector is determined by the energy hitting that pixel and the size of the pixel. If you change the size of the pixel, you may gain or lose energy faster than you gain or lose area. So if you change the pixel size to be slightly larger and suddenly one of your pixels happens to intersect a lot more rays, you could see an increase in the intensity. But if you pick up no new rays and the area is larger, you would see an increase. Generally, this is why you want to have a lot of rays, enough to get many rays per pixel in the region of highest intensity.
Kevin Scales
  • 185 replies
  • January 5, 2024
Manikarnika
  • February 5, 2024
Hi Kevin,
Thanks for your response.
I understood how the Zemax detector works but for a particular luminaire peak intensity and beam angle should be same. How to achieve the correct value for that luminaire using Zemax? because in LAB using goniophotometers results would always be same for a particular luminaire.
This is a major issue for small beam angles like 15 deg.
Currently I am using 10M rays.
Please suggest a possible solution.
