I designed an optical system and I wanted to compare Geometric MTF of 2 different Entrance Pupil Diameter (5 mm and 10 mm). I opened the window and saw the MTF. And I realized that MTF of EPD 10 mm is better than MTF of EPD 5 mm. However, the 2D plot of EPD 5 mm better than 2D plot of EPD 10 mm. Anyone can me explain it? I can’t understand why MTF with EPD 10 mm better that MTF with EPD 5 mm. I thought, it should be contrary.
