Laser diffraction interference pattern for coated wire
  • September 28, 2022
  • 45 views
anandr05
I am looking to visualize the laser interference pattern for coated copper wire. I am just starting with Zemax, so I began by attempting Young’s pinhole experiment. As I understand the basic flow, I would like to proceed to the actual problem. Can you please direct me to the appropriate resource? Basically, I want to
  1. Define laser source, wavelength =532nm. ( No specifics for now. I just wanted to generate a basic model)
  2. Introduce a wire obstruction between the source and the detector. Apply the characteristics.
  3. Ray trace and view the interference fringes in the detector.
I would greatly appreciate any help with this problem. Thanks a lot.
Regards
Anand
Be the first to reply!
