Elliptical mirror in non-sequential mode, standard surface or similar
  • November 25, 2019
  • 528 views
I am using a Standard Surface to model a concave mirror in non-sequential mode. The curvature of the mirror is defined with the Radius parameter.
To correct for aberrations I want to use two different radii, one along X and one along Y. Which object should I use for this purpose?
Best answer by Matthew.Cliffe
Hay Jonas
I think the surface you may be looking for is a biconic surface.
Hay Jonas
  • Visible
  • 23 replies
  • November 26, 2019
Exactly what I was looking for, thanks!
