Merit functions used for optimizing the final image size for light collimation
  • April 19, 2022
  • 941 views
Dion
I have an optical fiber and a lens for collimating. I have used some fields to represent the fiber output with given numerical aperture and  I want to optimize the final image which should not be not more than 17mm diameter. Is there any specific merit functions for this task and how to do it.
Best answer by David
Hi Dion,
I responded to your earlier post. In the example I offered, the REAY operand is used to define the edge of the 17 mm diameter final image.
Mod edit: The other post may be found here: How to design an optic fiber bundle? | Zemax Community
  • 337 replies
  • April 21, 2022
Hi Dion,
