POWF and POWP calculation,
  • September 8, 2021
  • 111 views
It seems to me that when Zemax calculate POWF or POWP, it doesn’t take into account of wavelength. Is that the case? The POWF or POWP should be varied with the wavelength, I tried to see it in the merit function editor and using ZPL programming, both of them gives me the same results. IS this the bug with the software?
Jessica Zheng
Best answer by Mark.Nicholson
The wavelength is passed via the merit function editor here:
  • September 8, 2021
Thanks Mark, I think I made a mistake here as my system is all reflective, that is the reason why those two operands won’t be affected by wavelength at all.
