change surface settings in spot diagram by ZOSAPI MATLAB
  • July 7, 2021
  • 156 views
I tried to change surface setting in spot diagram by ZOSAPI MATLAB and get spot position info by the following commands in MATLAB:
spot.ApplyAndWaitForCompletion();
spot_results = spot.GetResults();
spot_results.SpotData.GetReferenceCoordinate_X_For (2,1)
spot_results.SpotData.GetReferenceCoordinate_Y_For (2,1)
Which command should I use to fulfil this task??
Hi Shih-Heng,
Standard spot diagram has its settings implemented in the ZOS-API.
The lines of code you need are
MySettings = spot.GetSettings();
MySettings.Surface.SetSurfaceNumber(5)
Those should be before you use ApplyAndWaitForCompletion, and after you've created the analysis. Replace the number 5 by whatever surface you wish to apply.
Hope this helps.
  • 1132 replies
  • July 7, 2021
Hi Shih-Heng,
Hope this helps.
