Hi support team,
We have a little problem, We have taken a point source in object space, collimating it with simple optics and trying to simulate an image using slide, in image space with detector rectangle. But the image in 'Image space' is visible in positon space, while in angle space it is only one DOT every time.
What we have observed that for collimating beam the detector always shows a DOT in NSQ.
Is there any specific setting/technique to observe the image in angle space, at the detector for collimating beams.
Please find some images for description.
Thanks in advance.
Abhishek
