Material index in universal plot
  • October 29, 2020
  • 49 views
Good day!
I am modelling a system in non sequential mode, that works with different media (basically, a refractometer). I was wondering, if you could make a universal plot, where some variable ( like the power on the detector) depends on the refraction index of the material of one of the objects.
  • 1089 replies
  • October 30, 2020
Hi Alexandra,
That sounds like something which would be more suitable for the ZOS-API because the power on the detector requires a whole ray trace.
I'm thinking about something like:
  1. Setup your material
  2. Run a ray trace
  3. Report the power
  4. Change the material
  5. Goto 2. until last material
  6. Plot power as function of material
I think there are some good resources on the portal for the ZOS-API.
Does that make sense?
Cheers
