How to Model a Polarizing Beam Splitter
Hi there,
I have created a standard beam splitting cube in non-sequential mode using two Prism90 polygons, with surface coatings of I.99 and I.50.
I am now interested in making a polarizing beam splitter. What is the best way to go about this in a non-sequential mode?
Thank you so much!
Best answer by Thomas Magnac
Hi Martin,
You can use a coating to pass or reflect specific polarizations.
Check out the ''IDEAL2'' coating:
Thomas Magnac
  • 105 replies
  • June 15, 2020
Hi Martin,
  • June 15, 2020
Thanks for the quick reply Thomas!
I do not have this IDEAL2 coating. Can you suggest where I may find it?
EDIT: I have found the IDEAL2 by going into my Coating Tools -> Edit Coating File.
Thomas Magnac
Yes, that's it!
You can edit your coating catalog to add, like I did with mine, a pass_p and a pass_s coatings.
Thomas Magnac
Hi again, I found an old file where I did a x-cube polarization splitter!
  • June 17, 2020
Hi Thomas, am I able to contact you via email or phone call to continue this discussion? I have some specific questions on my PBS design.
Thanks!
Thomas Magnac
Sure, you can create a support ticket from MyZemax.
