Sag table output format
Alberto.Donazzan
Is there a way to tell ZOS the numeric precision I need in the sag table output?
Let's say I have an even asphere, specified as 3/ 3(0.5) @550nm, of which I need to generate the sag table.
The irregularity specification tells 550nm/4 = about 140nm. So there's no reason to go below 10nm with numeric precision in the sag table. Therefore I would like, for the sake of legibility and simplicity, to send the manufaturer a sag table with numerical values rounded to the 10nm, or 100nm, or whatever makes sense for my application.
In contrast, ZOS always splits angstroms.
Thank you a kind regards
Berta.Bernad
  • 112 replies
  • July 15, 2020
Hi Alberto,
The data displayed in the Sag Table Output text is hard coded into the program and currently there isn’t a way to specify the significant digits there. However, you can try to write a ZPL macro to loop over the surface X and Y coordinates and return the sag information with the Optimization Operand SSAG. Have a look at this article that explains how to get the value for an optimization operand in a macro.
Then, in the macro, you can speficy the numerical precision with the keyword FORMAT:
The Programming Tab > About the ZPL > KEYWORDS (about the zpl) > FORMAT
Berta
Alberto.Donazzan
Thank you for the advice. Are you planning to soft-code the Sag Table Output text in the future?
Berta.Bernad
  • 112 replies
  • July 16, 2020
I'll ask our Product team, and they will evaluate this as a potential feature request based on impact, difficulty to implement, and the number of users who request them.
