Diffractive Backside (NSC)
  • March 4, 2022
  • 72 views
mjean22
Is there a simple way to make the backside of a NSC Diffraction Grating/User Defined+DiffractionGrating.DLL the diffractive side? I’ve been fighting with rotating objects 180° and then fixing the effects of that but that allows for too many places to get lost and complicate my builds. Is there a setting or trick I’m missing or should I attempt a custom .DLL? Important note: I’ll split these by a _RCWA.DLL
Best answer by mjean22
Got it! Using a User Defined Object+Polygon_grating.dll and setting Parameter 5 (“Back side diffract”, I believe) = 1 allows for the backside to be the diffractive side!
mjean22
  • March 16, 2022
