Centroid in Huygens PSF
  • March 14, 2021
  • 140 views
The PSF centroid is computed only for Huygens PSF. Is it computed as a 'centre of brigthness' of the PSF irradiance distribution?
Regards
Best answer by Mark.Nicholson
Hi Jose,
Are you referring to the 'Use Centroid' control on the Settings tab? This will locate the center of the plot of the geometric image centroid, and is therefore the centre of brightness of the geometric spot irradiance distribution.
- Mark
Hi Jose,
- Mark
