Resolution in an imaging system with a microlens array
Is there a way to find the resolution of a system that uses a microlens array (MLA) for imaging in sequential mode?
Using the spot size (airy disc) or MTF doesnt seem to work with arrays.
(I used the user defined .dll for building the MLA)
Be the first to reply!
