Simulating PTFE Integrating Sphere
  • October 28, 2022
  • 319 views
SM_PhD
I’m trying to simulate a PTFE Integrating Sphere using the predefined macro that we can find in sample files
 ...\Zemax\Samples\Non-sequentional\Miscellaneous\Integrating Sphere.zmx
I was able to change dimension of sphere and port
but im finding the following problem:
1. How can I change the material MIRROR in PTFE?
2. Can I inserti a material inside the sphere?
3. How Can I calculate the number of refraction inside the sphere and the number of photons that reach the detector?
4. How Can I simulate the Homogeity inside the Sphere?
5. The detector viewer doesnt work, how me always the same results….Why?
A guide about simulating an integrating sphere can help me so much...Thanks for the support.
The code is as attachments.
Best Regards.
Be the first to reply!
