Unable to use the raydatabase and filter on NSC detectorviewer in ZOS API
  • June 30, 2025
  • 34 views
mocquin
I don’t understand how I should set the Filter and RayDatabaseFile of the DetectorViewer in non-sequential mode.
SHould I use :
DetectorView = zos.system.Analyses.New_DetectorViewer()
or :
DetectorView = zos.system.Analyses.New_Analysis(zos.ZOSAPI.Analysis.AnalysisIDM.DetectorViewer)
Then should I use :
settings = DetectorView.GetSettings()
and/or ?
        settings = zos.ZOSAPI.Analysis.Settings.RayTracing.IAS_DetectorViewer(settings)
Then using :
        settings.RayDatabaseFilename = db_file
        settings.Filter = "h9"
Those seems to make the analysis fail
Ansys Staff
  • Ansys Staff
  • 402 replies
  • July 15, 2025
First, make sure your system is in non-sequential mode before opening the Detector Viewer.  You can use TheSystem.MakeNonSequential().
You can use either New_DetectorViewer() or New_Analysis(); underneath the hood, these are the exact same method with the ZOS-API.  I personally like using New_Analysis_SettingsFirst() since this will open the analysis without running it first (there are some long-running analysis like POP that this could make a difference).
As for the settings, you should use DetectorView.GetSettings().  The IAS_DetectorViewer is an interface and cannot be used like a method.  If you’re using Python, it’s always a good idea to cast the parent implementation of the setting via DetectorView.GetSettings().__implementation__ (this will inherent any methods from the IAS_ parent interface like Field, Wavelength or Surface if the analysis has these implemented).
Finally, the ZRD file should be in the same folder as the non-sequential ZMX file.  If you haven’t loaded a ZMX file, then the default folder will be Documents\Zemax\Samples.
