ZOS-API with PSF in Matlab
  • December 11, 2023
  • 231 views
kot_letova
I write next code, but it gives me incorrect PSF. Can you help me with finding of mistake?
function [r] = BeginApplication(TheApplication, args)
import ZOSAPI.*;
    % creates a new API directory
    apiPath = System.String.Concat(TheApplication.SamplesDir, '\API\Matlab');
    if (exist(char(apiPath)) == 0) mkdir(char(apiPath)); end
    % Set up primary optical system
    sampleDir = TheApplication.SamplesDir;
    % Open file
   testFile = System.String.Concat(sampleDir, '\API\Matlab\TwoSystems.zos');
   if (exist(char(testFile)) == 0)
        fprintf('You need to run Example 01 before running this example\n');
        r = [];
        return;
    end
    % Create analysis
    % Open the Huygen's PSF. We will use the default settings for now
    huygensPSF = TheSystem.Analyses.New_HuygensPsf();
    % Settings
    huygensPSF_Settings = huygensPSF.GetSettings();
    huygensPSF_Settings.ImageSampleSize =  ZOSAPI.Analysis.SampleSizes.S_128x128;
    huygensPSF_Settings.PupilSampleSize = ZOSAPI.Analysis.SampleSizes.S_128x128;
    huygensPSF_Settings.ImageDelta = 0;
    %! [e04s03_m]
    % Run the analysis with the current settings and pull the results
    huygensPSF.ApplyAndWaitForCompletion();
    huygensResults = huygensPSF.GetResults();
    %! [e04s04_m]
    % The results will be split into multiple data structures
    % One structure will house the header information
    % Another structure will house the relative intensity values
    % Pull the structure with the intensity values
    matrixData = huygensResults.DataGrids(1).Values.double;
    % OpticStudio has pixel (1,1) in the top left of the matrix
    % Matlab places the (1,1) at the bottom so we need to flip the matrix
    huygensData = flipud(matrixData);
    % Use pixel data to create a figure
    % The jet colormap will match closely with the False Color plot
    imagesc(huygensData)
    colormap jet;
    axis square;
    % Close the Huygen's plot
    huygensPSF.Close();
    r = [];
end
kot_letova
  • Student
  • 5 replies
  • December 12, 2023
 The PSF chart doesn't depend on the system I use for analysis. It gives me one picture for different systems
