How STAR converts temperature into index of refraction
  • Jun 26, 2024 1:27 PM UTC
  • 240 views
Hi, folks.  One of our users asked about how temperature is converted into index of refraction.  Raytracing inside Zemax is fairly complex; there is an explanation inside our Help files under “Index of Refraction Computation.”  We use a formula developed by Schott.
The constants in the equation are in the material’s library data.  Not all materials have a complete list of the coefficients.  If a material only lists the D0 value, then the change in index with temperature is purely linear.  That is okay in some situations; usually for temperatures near room temperature, where the D0 coefficient was likely measured.  In general, though, the relationship is non-linear.
Because we don’t often look at how index behaves with temperature, here are a couple of plots for N-BK7.  Index tends to rise slightly with temperature.  The rising slope is much smaller than the change in index as a function of wavelength.  And the index change is greater for shorter wavelengths.
Jaroslav.Zadnik
Great, thanks for overview :)
