Zemax license visible but unavailable after Windows update
  • Jan 20, 2022 11:25 AM UTC
  • 6 replies
  • 282 views
IT services in my institution had to update Windows on my PC. I am an end user in a shared network perpetual license. However, although the HASP reads Okay and I can see the license in the license manager, on starting up optic studio I get an error message stating that no license was found. When reviewing similar questions I see people recommended to transfer the license, however I did not do this and would like to resolve this issue.
Your help would be greatly appreciated.
Best answer by Don Dickinson
Ok thanks!
I looked that license up. It actually was renewed and support doesn't expire until June 2022 . Apparently nobody applied the update on your end.
You will need to find some one there with access to the license server machine called JMUDAS6 . They just need to log in to that machine and launch the zemax license manager. It will automatically retrieve the update.
​​​​​​In the meantime until that's done you could install a release of opticStudio from may 2021 or older and it will work.
Greetings,
Odd issue, normally Windows security updates don’t affect the license. They didn’t upgrade you from Windows 10 to 11 or something did they?
You cannot transfer the license since it’s a network license and activated on the server rather than your machine. Can you share a screenshot of the “view license” section in Zemax license manager? Also, please click “details” or the license number on that same screen in the license manager, and attach a screenshot of the details as well.
Thanks!
Don D
  • Jan 21, 2022 8:12 AM UTC
On closer inspection looks like the license I was trying to use support ended last year. That must be what happened? I’ll check this with IT purchasing.
Apologies
What’s the license number you are accessing? It may still work even if support expired, though you would have to use an older version of Opticstudio if that is the case
  • Jan 22, 2022 3:54 PM UTC
Thanks, screenshots with the license key and error message attached.
If I just have to use an older version of opticstudio then that’s no problem.
  • Jan 22, 2022 5:46 PM UTC
Ok thanks!
  • Jan 24, 2022 2:04 PM UTC
Thanks Don,
I found the person with access to the license server and got them to launch the zemax license manager to apply the update.
It worked after that.
All the best,
Éamonn
