No license found
  • 25 January 2023
  • 198 views
I can see in the license manager that I have a valid license for OpticStudio Premium, however when I try to open OpticStudio I get the following error pop-up.
“No license for OpticStudio was found. If you are attempting to run from a USB key, ensure that the key is plugged in. To activate a new Softkey, open Zemax License Manager.”
This license was working for most of the day without problems, half way through ray-tracing the software closed (might have ran out of memory) and when I tried to re-open this occurred.
Any advice would be greatly appreciated,
Josh
icon
Best answer by Josh135346 26 January 2023, 11:41
Userlevel 3
Badge
Hello!
Sometimes just a computer restart will get things sorted when this happens.
If that doesn’t clear it, another option is to try transferring away the license and back again. No need for a 2nd machine. Just use the transfer code immediately after you receive it. https://support.zemax.com/hc/en-us/articles/1500005486461-Transferring-and-updating-a-softkey-license
Hello!
Thanks for the answer Don,
I get the following message when I try to send the license:
“Cannot transfer the license with the information provided from the Zemax server. Be sure the license is not in use, and launch Zemax License Manager from the Start menu rather than within the software (Done). If this error persists, please contact support via zemax.com.”
2023-01-26 10:06:26 [20604] Fridge is not supported in this machine
2023-01-26 10:01:54 [20604] Error probing server '192.168.41.255:1947' (in send) after 0 [ms] (syserr 10051/WSAENETUNREACH)
2023-01-26 10:01:54 [20604] Error probing server '192.168.21.255:1947' (in send) after 0 [ms] (syserr 10051/WSAENETUNREACH)
2023-01-25 21:15:22 [20604] Disabling storage. Local software licenses won't be accessible
2023-01-25 21:15:22 [20604] Failed to commit transaction in the storage. cannot commit - no transaction is active
2023-01-25 21:15:22 [20604] Failed to finalize in the data store. database or disk is full
2023-01-25 21:15:22 [20604] Failed to write in the data store. database or disk is full
2023-01-25 21:14:59 [20604] Failed to commit transaction in the storage. database or disk is full
Got the above in Sentinel Admin Control Center
I re-ran the Sentinel driver installer, selected repair, and restarted my PC and everything is working again!
