Saving the Partial Coherent Image Analysis Results in ZOS-API
  • February 17, 2023
  • 180 views
Who do I save the ZOSAPI.Analysis.AnalysisIDM.PartiallyCoherentImageAnalysis results to an image file such as a JPG or BMP?
Thanks
Hi @David.Borja and @Jeff.Wilde
I did a quick test. The settings are not implemented but this analysis returns a grid. So you could save that grid (which is basically the content of the text tab) and plot it in another software.
  • 506 replies
  • February 17, 2023
This question has been a previous topic of conversation within the forum.  Unfortunately, as far as I know, the bitmap image save function is still not hooked up in the API.  However, there is a workaround using ZPL keywords EXPORTJPG or EXPORTBMP (via a ZPLM merit function operand) as discussed in these two threads:
